natedog337
- Joined
- Jul 11, 2011
- 107
Located a corroded wire split on my boat which was giving me no power to my circuit breaker. The single power wire was running from my batter to my circuit board compartment. The single wire was split into two wires with only shnk wrap which completely corroded out. My question is I'm going to install 2 new wires at the split and was thinking of using a crimp connector to tie the connection together and also using liquid electric tape to avoid any corrosion. Any options and what size connector should I use. I think a connector for 10ga wire may be too small as I'm tieing two wires together
