Sporatic Engine Power
Aqua Chalet
1984 115 hp Johnson outboard TLCRD
Engine ran fine, I hit a rock and chewed up the 4 blade alum prop. Made it back to home and put old 3 blade alum prop on
Engine went from running fine on lake next day(45 minutes) to reduced power without touching throttle. Engine seemed to slowly reduce in power until I throttle back and reapply. Engine power would reduce then jump back up for a while. Next day, Engine difficult to start unless choke all the way.
Low power with throttle at 3/4 then without touching throttle the engine would power up suddenly then seconds later power down without touching throttle.
​I later discovered I was putting too much oil in gas- closer to 40: 1 ratio than 50:1.
Its a VRO fuel pump and I just plugged the oil outlet and mix the gas.
Is it possible too much oil caused this.
Engine completely rebuilt except alternator and regulator.
Fuel pump and hoses are new a year ago. Old Fuel pump still worked but leaked around gasket.
flyingscott
I doubt the pump was the problem. What kind of clamps did you use on the fuel lines sounds like air in the system.
ondarvr
Oil ratio won't do it.
Don't run it like that, if it's carburetor issue you could destroy the motor. It's either running lean from a plugged carb, or possibly a coil is failing at high RPMs. Check for spark when it's acting up, use a timing light or an inline spark test light on each plug to see if there's a problem.
emdsapmgr
Good idea to check the ignition components on the engine. They can tend to work/not work-similar to your problem. This website has some xcellent troubleshooting info for your engine: cdielectronics.com. Better than the factory manual on these early models.
