Sport Jet 120 Red Stator 2 Yellow Wire Voltage
clay37355
Ive got a sport jet 120 with the red stator. No spark condition. I ohm out the Green/white to White/green wire and it shows it is in spec. I check the ac voltage coming out of the 2 yellow wires from the stator and im only getting 3 or 4 volts ac. Shouldnt this be alot higher? I do not have a dva meter. Im just checking standard ac voltage from my meter
Thanks
Anders67
Re: Sport Jet 120 Red Stator 2 Yellow Wire Voltage
Hi
Do you measure between one yellow at time , and ground ?. Enritciner and retic. disconected?.
15 amp stator between to yellow 0,15-0,20 resistance ohm scale Rx1
Between yellow and negative ground no continuity Rx1000
The yellow side does just matter to auto enritchiner and battery loading, as long as it?s not broken so it?s short cutted.
You can disconnect kill wire (yellow/black line), reticif., rew limiter, one at time and see so they not short cutted. If, they can cut out the ingnition ore voltage.
