Sport Jet 90 Crazy Compression Check
trpaddy
Let me start from the beginning.<br /><br />Last summer my boat ran great, top speed of 43 and never ever had a problem. At the end of the season, last ride, the boat would not throttle up, it would get to about 10 miles an hour than almost stall. Would start very easy and idle smooth. Found the fuel pump a little loose. Fixed that and without testing it, put the boat up for winter. <br /><br />Winterized it, ran it with a hose properly installed as mentioned in the Clymer book and in this forum.<br /><br />Spring time, went to start boat, could not spin engine, was very difficult for battery to spin motor at a decent pace. Replaced battery and had an idea to pull plugs to check cylinders as I knew thse engines had water leak problems.<br /><br />A large amount of water came from number three. I know that if all gaskets are good, no water will get into system. Correct?? Have read conflicting views on this in this forum.<br /><br />Anyway, did a compression check:<br /> Top = 120<br /> #2 = 145<br /> #3 = 175<br /><br />What is going on with these crazy readings. I know the top will be 10-15 lower than the rest but these numbers make no sense to me.<br /><br />Any ideas??
marinegrh
Re: Sport Jet 90 Crazy Compression Check
usually around 15 - 20 psi difference i start wanting to think something is going on inside the cylinders, you may want to pull the head and inspect the pistons and cylinder bore, i am willing to bet a lure you may have something funky going on, ie; bad rings, damaged crown, or scored up walls, you have 55 psi difference something aint right
bobrock
well the high reading on #3 cylinder is because of the water ... the question is .. where did it come from and how long has it been there ..<br />might be a good idea to pull the head and look for damage.. the water could come from 3 possible sources that i can think of ... blown head gasket.. cracked block .. or water vapor drawn thru the exhaust from a bad set of reed valves good luck.. keep in touch
kenimpzoom
I personally would run it for about 5 minutes at a medium speed, and then retest the compression.<br /><br />I have heard reports of water getting into #3 while running on the hose, but I have never experienced the problem.<br /><br />Ken
