bedwards36426
Thread starter- Joined
- Jan 30, 2012
- 76
Ok so I'm still learning the ropes with this boat I've recently purchased. 94 Sea Rayder Sprt Jet 90. Got it where it will start cold with just the turn of a key. Got all the recirculation lines cleaned check valves and all where they will stay on. So off to the lake. I backed the boat in and left on the trailer to run it. Started right up only rev up to warm up a few seconds then let idle for about 20 mins. Just siting back monitoring those fuel lines and temp with a infrared temp gun from work. Temp stayed about 140 degrees the whole time. After about 20 mins of idle the motor hiccuped once then about a min later the overheat alarm sounded so I shut off checked temp and it was 200 degrees. This happened all in about a min. Was running 140 before all this happened. Any explaintion as to why this could have happened. I'm still nervous to take it out. So that's why I left on the trailer. Could I have let it idle to long. Maye the thermostat stuck? Any ideas? Thanks for all the help I've been given to this point.
