FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
As far as strator and voltage reg, I think I found the ones I need. Gonna check around for best price. I guess I'll be back when I get them and install them. Anything I need to be particularly aware of? Or anything to look out for? Aftermarket voltage reg? I know to get the red stator, but the OEM volt. reg will be fine?
need some help, guys. Im looking @ stators and Im finding red ones and red kits. The kits come with the candybar shaped black box. Am I ordering a red stator and a voltage regulator or am I ordering the kit and the candybar replaces the volt reg??
ok, guys, I got the red SIERRA stator and voltage reg today. Put the stator on and im a little confused. I have 2 yellow, a green and a white wire coming from the stator. Of course the yellows go to the existing yellow wires. But the old black stator had red/white and blue/white going to ground and a red and a blue going to the switch box. thats 4 wires. I have a white and a green.... where do they go?
I also have my new voltage reg. the new one has 2 red, 2 yellow and a grey wire. The old one only has one red wire. Wheres the 2nd one on the new one go??
Did they come with instructions ? I will have to research sierra products to give proper advice , Sounds to me like you have some updated parts that will need some adapters . Hurricane is closing in here will post up when I can . I am quite sure that the red wires will need to go to a 20 amp fuse adapter (connected to each other through the fuse ) the stator wires will either need an adapter or they will go to the switchbox directly , post up the part number of the stator you got , that will help .
Apparently i ordered the wrong parts. Sierra doesnt make a replacement stator for my application! Wtf? I gotta return the parts and find the right ones.
Alive and well , Had computer problems and internet connection problems , Also things went sideways at work and have been doing 16 hr days to get things back on track . Now back to your stuff . CDI makes a direst replacement stator for your boat , I will post up the numbers later today , just catching up right now !
Kend, i know ur checking on the stator, but could u also include part numbers for the voltage reg, coil mag #1, ride plate, grate, impeller, wear ring..... or tell me whhat web site i can plug my SN into and get the part numbers?
this is a good thread, i also just baught my first boat for cheap and am in the same position of rebuilding the engine, although i havnt started yet cause of $$, but i plan to get it up by next summer. my jet is fine but my sport jet 90 engine looks like it needs a good overhaul....ill be staying tuned and watching....thumbs up to kend for all the good info
not sure exactly what the cdm conversion kit is but i assume it has to do with the stator replacement as they seem to sell the correct stator(i think, i am just learning) for 225$
Hate to do this but Jon you are just learning as you said , yes that stator will work but not when converting to a red stator from black , It will kill the entire ignition system with a switchbox with out the conversion kit adapter . The CDM ignition system is entirely different and parts for the kits should they fail are no longer available for the 93-96 Sport Jet
