sportjet 120
sjbs
Can you use a 1996 crankshaft in a 1995 block? The manual shows the bore and stroke and mains are the same. The rod journals are larger on the 1996 crank.So if you use the 1996 rods and pistons and the crank will it work in a 1995 block? Thanks,Steve
