this may be of intrest to you.........from what ive read a good pressure tank is woth its weight in gold
http://forums.iboats.com/showthread.php?t=205628
I have a small black button that you push to prime the fuel system. It will not hold pressure.....You say 'bulb'? There is no bulb on the hose for a pressure tank. It is a little black or silver button on the tank that is used to pump fuel to the carb before the pressure builds up once the engine is running. Is this what you have? Also the cap must be tight for the system to work.
