Re: spotlight wiring
No<br /><br />Not sure what you mean when you say can you wire your lights to a 24 Volt source, when they are only 12 Volt lights. Obviously, you will have 12 volts going to the rest of the components on your boat(Except maybe for a trolling motor), so I see no reason you could not run wiring from the 12 Volt battery to a switch and then to the lights. That's how I did it. I had an aux. switch on the panel already and used that to power up the lights. Pretty easy, except for crawling around under the trailer to run the wiring to the lights. You will blow the lights out running 24 Volts to them if they are rated for 12 Volts..<br /><br />Also, do not attempt to run 24 volts to any component rated for 12 Volts. Like your starter, for example...
