Spray "bedliner" to replace carpet?
jason389
My boat is 12 years old and the ugly red carpet needs replacing. I hate it anyway and thought of having the deck "sprayed" with a bedliner type material, or even trying to do it myself. I don't think the extra weight would be a huge issue....has anyone tried this? Any advice or thoughts? I would try to go with a light color so it wouldn't be hot...but I think it might work ok.
-Jason
Bob_VT
Re: Spray "bedliner" to replace carpet?
Jason..... we have many iboats member's who have had good luck using Durabak (a non slip deck coating) and we have also had a few nightmares about bedliner!
Google Durabak and they have many colors too. ;)
cjcliff
Boats are sprayed frequently with "bedliner" material, you just need to make sure it is an aliphatic product, especially if you want a light color. An aliphatic polyurethane won't fade or discolor like any normal polyurethane will. Rhino Linings has one called SolarMax and it also will give you the non-slip properties you need for a boat.
Surfer Dave
I sprayed bedliner in my boat, it is a 1973 Baja, and I love it, way better than carpet
Fireman431
Isn't a spray-in bedliner a little rough on the bare feet? Especially if there are little ones also?
NYBo
I just got a sample of Durabak in the mail. After seeing it, that's what I'm going to use. I don't plan on being barefoot in the boat; the Durabak would probably remove any calluses I had.:eek:
cr2k
If you DIY both rattle can and roll on bedliners can be applied from either super rough to fairly smooth. It is the way you apply it.
mphy98
There is a bedliner that is more rubbery than others and can be made any color you want. I forget the name but I am sure you can search and find it.
mike1245
i used herculiner and love it it was 77$ for a gallon and can be painted any color you want
sawblade723
I used the gray Herculiner in my bass boat and I love it. I covered the floors, decks, and hatch lids and it turned out better than I expected. Maybe I can get some pics on here soon. It is also very easy to do it yourself.
Friscoboater
I used Durabak and I love it. It does hold dirt though. I just got a deck scrubber from West marine and it is all good.
Ayuh,... I'm wantin' to do Roll-on for my houseboat decks,...
Which 1s of these are the Rubbery, vs. Plasticy feelin' 1s,..??
I'm looking for a light grey or blue, or aqua color...
smarks
I'm going with the Durabak as well, I was told by someone in this group to put one heavy coat of the textured and two coats of the smooth. This would still have the non-slip properties but be smooth enough as to not collect dirt.
Also, go with a light color so it dosen't get so hot on the feet.
Regards
Steve
jason5975
Is the durabak too rough for bare feet? I do have lots o' barefooted little ones aboard my ship frequently.
Shife
KiwiGrip:
http://www.kiwigrip.com/
I highly recommend this stuff. I've never used Durabak for boat decks, but I have used it to line 'glass Jeep tubs and was happy with the results.
kfouryou
sorry has anyone tried tuffcoat from pro bass shop?
ezmobee
No but I wish someone would so we'd know as I've seen a number of users ask about it. Overton's has a branded coating as well which I'm sure is the same thing.
bear_69cuda
Hey Bond-o
Durabak has the rubbery texture. If I did another deck, I would apply one heavy coat textured, and seal with non-textured. I applied 3 coats of textured to my Bayliner deck, and it was to much... They have the colors you want also...
Durabak is tough stuff!
