spraying Interlux perfection paint
JJB
I wanted to know what is the Best type of spray gun to use when spraying interlux perfections paint . also how much PSI would I need to do the job right . Thank's for the input JJB
rockyrude
Re: spraying Interlux perfection paint
If you don't have a "haz mat" style spray outfit don't even atempt it, it's way too dangerous. The roll and tip method is actually almost as fast with equally good results.
Capt. Valk
If you do have all the equipment, the supplier should have a data sheet with tip sizes, pressures ect. If not then the companies website should. Spraying isn't as easy as it looks if ya haven't tried it before ;) Either way always wear a respirator. If ya have no experience spraying, listen to Rocky. He speaks the truth :D You'll have a 200% better chance of having a nice paintjob with the roll and tip method if not experienced. Ship Shape TV had an excellent episode on how to roll and tip. You can buy the videos I think.
Tail_Gunner
Take head here, Perfection has ingredient's that can really mess you up permentaly. You need a suit with it's own air supply...
Youll need a pot sprayer say a bink's with a .50 tip.
JJB
Hey , Thanks for the life saving info ! Will roller and tip for sure ! JJb
wire2
Basically, it's a 2 part polyurethane. The hazardous ingredient is cyanide. It's a very low percentage but still potentially harmful if inhaled as mist from a spray gun.
On the plus side, it's as glossy as glass, UV resistant, ignores gasoline and most chemicals, is VERY scratch resistant, and remains flexible on fiberglass. Application is newbie friendly, as it flows together smooth and is run resistant.
I did a classic '75 GMC motorhome in 2 shades of blue, gray & white with it using a Binks cup gun, turned out beautiful. 5 years later, it still looked exactly the same.
If there's a choice, choose the thinner with longer cure times, so that it blends together where you start & stop.
impman
3m disposable resperator, about 20 bucks. gloves hat and any gun with a 2.0 tip. your good to go
rockyrude
A disposable respirator WILL NOT fiter out the toxic ingredients in interlux. I would defintely warn against it. Tail_Gunner wasn't kidding.
gcboat
You really need to read this:http://www.yachtpaint.com/USA/hotlinks/perfection_manual.pdf
On page 13 you will find your tip sizes. They will, and do vary from gun to gun. This is a forty page download so if you don't have a high speed connection hang in there. Might take a minute or two. Again, if you plan on using the Perfection - please download and read. :D
impman
A disposable 3m resperator is good for 24 hours opened. The main ingredient in a true poly and most urathane paints is isocyanate, and yes its deadly . but if you spraying it out doors (not an enclosed building) and using a (new unopened resperator). you should be fine. Ive been doing auto and boat painting for 22 years now, I just talked to my paint rep and the rep from 3m... they agreed. I hope they are right, Or else I will be dying tomorrow
drewpster
Back when I was trying to decide this subject I spoke with several folks about it both in here and guys I met through my job. The opinion that stood out most was a local boat refinisher and repair guy. He has an outstanding reputation around here. The trouble I had was that he is Asian and has a thick accent. Despite the language barrier he was very adamant about one point. Perfection is a paint that has to be applied using specific techniques to get a good result. An experienced applicator can apply it easily but there is a definite learning curve. He recommended rolling it. It would simply cost too much to get the equipment needed to spray it. And to buy the extra paint I would need to cover my mistakes.
He did not state this as clearly as I did here. I remember something like: You no paint sprayer, you roll, easy crew up, too mush windy, cost plenty. He had a good point, smart guy. He is my best friend now.:D
drewpster
Perfection roll/tipped baby!
penst8grad
The Jamestown site has the tip and pressure recommendations.
drewmitch44
Drew that a greap pic comp video thing. I love it a story. Cant wait to see it in the water.
hwkypuck
I have restored many boats over the years. Spraying or roller/tipping, if done right its about the same. Spraying is better if you work alone and time is an issue. If you are a shade tree mechanic and work out of your back yard. You should consider your neighbors when spraying a very toxic paint. Good luck
Mark42
Note to self: Strike Perfection from the list of paints to use on the hard top project because it will show every imperfection and mistake I make in the fairing and prep. Maybe flat white Rustolium will work..... :D
Tail_Gunner
That's what they have bond-o errrr faring compund...getting lazy Mark...:D
hwkypuck
With proper mask, I have used a simple 8oz. gravity gun thin it 20% with interluxs thinner. Keep a good brush close in case you over spray. Remember USE THE PROPER MASK!!!!!!!!!!!!!!!!!!!!!!!! Good luck
