drewpster
Thread starter- Joined
- Oct 17, 2006
- 2,059
I was very pleased with the finish that the Interlux Brightside yielded on my deck. However I have allot of painting left to do and I want to try my hand at spraying the finish from here on out.
I bought a mid priced ($150USD) gravity feed HVLP gun with the largest tip it came with. Just for kicks I tried to shoot some primer (Interlux Pre-Kote) with the gun. I thinned the primer 10% with the recommended 216 thinner per the maximum on the primer directions. It would not flow no matter what setting I tried. I was not really surprised as Pre-Kote is very thick and has balloon fillers. Also the gun I bought is based on what Interlux recommends for the paint, not the primer. So, no problem, I just rolled it and tipped it off.
I was limited on time so I did not try the gun with the paint. This paint is expensive so I am trying to beat the learning curve a little. Has anyone got any recommendations on setting up to spray Brightside Paint with a gun like mine? I used Interlux's recommendation to select the gun when I bought it so it should work. If I can get a technique down well enough, I am planning to shoot the outside of the hull using Perfection. Any recommendations here as well? I am not against roll/ tipping to apply the paint, I however I think shooting it would make it look even better.
