Scott in MN
- Joined
- Jul 28, 2003
- 46
This seems to be a common question. Here is my scenario.
1980, Sea Ray SRV 225 with a Mercruiser 228.
I had been experiencing some overheating problems this year but only at high rpms. Still I had no problem getting up on plane and there was no slippage to the prop. I figured the overheating to be something with my impeller or thermostat so until I could address it I just cruised at lower rpms (<2000 rpm). Occasionally I would take it up to 4500 rpms but only for a few minutes as I watched the temp gauge slowly climb.
Last Saturday I went for a long cruise and as I approached the marina I brought it up to 4000 rpms for the final stretch. About two minutes into this I started hear noises in the back and then suddenly my engine raced. I immediately backed off the throttle and put it into neutral. I then noticed that my temp was higher than I would like and thought I smelled some burned rubber. I put it back into gear and started limping back to the marina at about idle speed. The temp came back down but the engine speed was no longer proportional to the boat speed. I could increase the rpms but I would not go any faster. There was slippage somewhere.
At first I figured I had spun the prop but after doing some more reading I'm wondering if it is my coupler. I'll do some tests this weekend but was wondering if this write up sounded like anything to you folks.
thank you
thank you
