Berdink
- Joined
- Mar 5, 2020
- 443
I will. Best to anyway.Have you checked thermostats?...clip...
Yeah, sorry. If the primer solenoid valve is stuck open and the fuel pump is pumping, the fuel would be just 'pumping' on through the primer solenoid straight to the carburetors, correct?The electric primer is NOT a pump.-----It is a valve.
Yeah mate , been there , you will get it sorted ,the problem you then have is that you know that after all the fixing you have done there is not a better used motor on the planet and thusly will never get what its worth if you decide to sell it . I call them "life " possessions ( my 30 year old Quad ) coz it will still be going when your not and you'll need a grandie ( grandchild ) to take it on so as to get the best most out of it .....good place to beActually, no, it's likely not stuck open. If it was, my primer bulb wouldn't get solid.
Nevermind.
I'm trying everyone's suggestions. And checking things you guys bring up.
I'm just not finding what's causing the issue, and I'm just searching and searching the forums.
Bright side is I'm going through so many things and verifying their condition.
And I'm learning.
No,The motor is 30 years old.----Expecting it to run flawlessly?
Done. Nice and clean inside as I posted earlier.Have you checked thermostats?....clip....
