Gas Giant
Thread starter- Joined
- Aug 8, 2010
- 239
Engine is a '61 Evinrude Lark III, 40hp, Model #35524
Long story short, the entire ignition system has been replaced. (points, condensers, coils, spark plug wires, spark plugs). Points were gapped to 0.020". Spark was verified with an automotive spark tester set to 7/16".
All of the engine's other wiring has been replaced.
The entire fuel system has been replaced, except for the fuel pump. (All new fuel lines and filter). Fuel pump was disassembled and cleaned out, and the diaphragm appeared to be in good condition with no holes or tears.
The carburetor was torn completely down, welch plugs and all, and soaked in a bucket of carb cleaner. When I took it out of the bucket I blew out all the passages with a can of carb cleaner. It was then rebuilt using an OMC carb kit P/N 439074.
However, I can only get the engine to sputter when I try to start it. I am using the pull starter as the electric starter still needs a solenoid, and after a few hours of tinkering and pulling, I am pretty darn tired. I tried it in the Choke On position, the Choke Off position, and the Automatic position (even though the automatic position is essentially the same as the On position when starting). The longest it ran was about 3 seconds, but for those glorious 3 seconds, it seemed smooth.
So, I'm not sure what to check first. It seems like a fuel delivery problem, but I'm open to ideas. The place I got my spark plugs didn't have Champions, so I have AC Delco in there for now - I doubt that could cause this problem, could it?
Anyway, any ideas as to what I should check or try next are appreciated. I'm not sure what to do at this point, and my arms feel like rubber.
