sqeaky tower
mmwest
does anyone know if there is a grease or something you can apply to a tower to stop some of that awful sqeaking noise it makes when im pulling my boat.........it's pretty quite on the water though but when i'm driving and my windows are down it sounds pretty bad ..........thanks
rallyart
Re: sqeaky tower
You could try white grease. I think a better solution might be to tie the tower so that the bars don't move. a couple cinch straps or bungee cords might make a bigger difference.
mmwest
Re: sqeaky tower
might give em both a try...thanks for the suggestion
DustyJoe
Re: sqeaky tower
Your best bet would be to row the windows up and if that don't work there should be a knob or button to the right of the steering wheel that says volume turn it up and the squeaking will be gone. Lol. What kind of tower is it. U could try some spray white lithium grease but I doubt that u have much room to grease anything. Have u re tightened everything?
mmwest
Re: sqeaky tower
yea i've tightened everything.i'm gonna take my allen bolts out and grease em and that'll probably do it..............in tennessee ya'll may row up your winders but in texas we roll up our windows..........sorry dusty i just had to do it .........row,row,row yur winders
Rinker97
Re: sqeaky tower
I would use Teflon tape, grease might make your bolts come out...
DustyJoe
Re: sqeaky tower
HA HA its all good. But you didnt answer what kind of tower is it?
mmwest
Re: sqeaky tower
it was custom made at a place called millinium marine in seabrook texas so that i would be able to use my exixting bimini
DustyJoe
Re: sqeaky tower
Cool have u talked to them about the squeak. Also are u sure it's not the trailer squeaking it just seems odd that it's quite on water but not on land. Have u got any pictures.
ThreeMileBayWaker
Re: sqeaky tower
put a thin rubber bushing/gasket between the mating surfaces. When I had to remove my upper portion for storage this winter, I found all my bolts my had like 1/8th rubber gaskets on them.
mmwest
Re: sqeaky tower
thanks for the feedback guys,be safe out there boating
scooper77515
Re: sqeaky tower
I cannot believe is squeeks on the trailer, but not on choppy water...makes me think it is the trailer itself, like Dusty said.
Mine wobbles a bit. The wife freaks out at times on big choppy days, especially when I have a board strapped on it. It will flex and sway and she thinks it will fall off (it won't!).
But I never hear any noise from it.
I will be on Lake Houston Sunday. Bring it out, I will apply intense pressures to it, utilizing my rope and my 200 lbs of body weight, and see if we can make it squeek!
mmwest
Re: sqeaky tower
The more I think about it ,it's probably my trailer making all that racket......ain't my first brain fart..they just seem to come more often.oh how i love gettin old.I mentioned something about going to Lake Houston to my better half this weekend,so we'll see how the weather holds out and we 'll definetly look for you if were out there.Isn't the lake pretty low right now?
scooper77515
Re: sqeaky tower
Lake is still 6-7 deep at the dock at Deussen Park. Only shallow place I am worried about is the river mouth up to Kingwood. We went out yesterday and it was glassy and AWESOME!!! 45 mph from one end to the other. Never hit the wake of another boat.
dca11y
Re: sqeaky tower
I take all my tower bolts out at the beginning of the year and put Locktite on them, should keep them tight.
