Squeaking leaf springs
robbyr1
I have squeaking leaf springs on my ez-loader trailer. They squeak when I'm on the way to the lake, but not on the way back (after they got wet at the launch). Can I just spray some WD40 on them?
bruceb58
Re: Squeaking leaf springs
They all squeak. Every trailer I ever had squeaked.
indy440
thats funny, my trailer is the exact opposite. Completely silent on the way to the lake, and incredibly squeaky on the ride home when they're wet.
This is a little extreme just for squeaking, but you could get a torsion axle suspension trailer.
robert graham
Buy a can of Spray Foam Roller Chain Lubricant, goes on as a foam, penetrates very well, and is very sticky to stay on leaf springs, that should stop it for good!
ufm82
Is it the springs or is it the suspension? If you have slipper type springs (as many EZ loaders do) the rollers that cover the bolts wear and you wind up with metal-to-metal contact. Also, is this a tandem or single? The bushing in the equalizer also wears and you get the same thing at times.
My tandem trailer squeaked like crazy until I went through the suspension and replaced all the sleeves and bushings. Now it's doesn't make a sound while towing. I replaced EVERY sleeve and bushing and I spent less than $60 for all the parts. Plus the alignment has to be better as the slop is gone out of the suspension.
UFM82
