- Joined
- Apr 17, 2002
- 71,538
Donno, I bought a roll of it at my local Napa,.....That stuff looks nice and I found some on summit as well. Any idea how long I'd need? Those sierra lines are 25"
'n, No, I don't remember how much,....
If you have a mercarb with the fuel inlet on the left side when you face the carb and your existing line may work.That stuff looks nice and I found some on summit as well. Any idea how long I'd need? Those sierra lines are 25"
Hey All! New register to iBoats, and sorry for the long-winded post, but I've been searching and reading since I got my boat back in early July. This is my first boat but I'm a pretty big car/motorcycle junkie. It's a 99 Rinker Captiva 232 Cuddy w/ 5.0L TB5 (0L096199) and a SEI16 drive (assuming Alpha One Gen II replacement). At first we were getting maybe 38-42ish on speedo, so I suspected some issues... Being that I didn't know how well the previous owner took care of it, I figured I should do the standard tune up. I did an oil/filter change, fuel filter change, distributor cap & rotor, new NGK TR5 plugs gapped at 0.045, and sierra 8mm wires.
First time out after those changes, it seemed to run well, but didn't gain any RPM and during the trip back to the launch, the coil wire popped off the coil pack and it was misfiring. Next day, I put in a MSD Blaster 2 (8202) coil and we also switched the prop out for a Turning Point 14.25 x 17P and 701 hub.
Back out, we were now seeing about 4200-4400 and 39-40mph (GPS on iPhone) on pretty choppy Lake Ontario, The motor ran very strong and everything seems to be good, but I want a little more out of it. The motor plate obviously says 4400-4800, so I'm just at the low end of that.
After reading the sticky threads on WOT RPM, I'm thinking the only thing left to check is if the throttle cable is allowing the carb to go fully open. Besides that, and since I'm not ready to investigate swapping a 350 short block into it, I was thinking a summit racing intake manifold and Edelbrock 1409 carb.
Thanks!
