bear_69cuda
Thread starter- Joined
- Oct 10, 2008
- 2,109
Hello,
I have a 1999 Bayliner 1950 3.0 L MerCruiser that gets to ~42 mph @ 4800 RPM with 21 pitch aluminum stock prop.
I'm prop shopping, so I can use my current aluminum stock prop for a spare.. The two times I've driven the boat, the current 21 pitch prop seems to have a good hole-shot, and nice top end. I now want to up-grade to SS, and have been reading about Mercury Stiletto and Apollo props. I understand these are progressive props. So that on WOT the prop has a bigger pitch correct? And that if I choose a SS 21 pitch for my boat, it would be 22-23 at WOT, and therefore, my boat may be over propped? Then my guess is to check out a 19 pitch version of the Stiletto or Apollo. That should be comparable to my stock prop correct?
Thanks in advance!
Thanks in advance!
