Sta-Strap or Hose Clamp
j442w30
Hi everyone,
I just finished rebuilding the carbs in my 1993 Mercury 40 horse 4 cylinder outboard. I am going to replace all of the fuel lines and fuel filter and I was wondering if I would be better off replacing the Sta-strap (which looks like a special zip tie) with a hose clamp. I would think the hose clamp would be a little tighter or would I risk cracking the plastic fittings? Those sta-straps are a real pain to get off.
thanks
rodbolt
Re: Sta-Strap or Hose Clamp
I just use the tie straps. they are simple to get off and install with a pair of diagonal cutters.
I do use the ones offered by BRP or merc that have the radius under the head.
j442w30
For the price the sta-straps are worth a try I just figured the hose clamps would be easier to get off. I don't know if there is a trick to getting the sta-straps off because I had to cut them off to remove them. The replacement sta-straps are 15 cents a piece so I guess better stick with the oem design. Just curious
I realize that this is an old post, but maybe this link will do someone some good!
Kable Kontrol Radius Clamp Head Fuel Hose Cable Ties, 4 Inch 100 Pcs, 18 Lbs Tensile Strength, Nylon UV & Chemical Resistant Hose Clamp Zip Ties for Indoor, Outdoor, and Industrial Use - Black​
https://www.amazon.com/dp/B0DQWK4L6W?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
