Stabalizers/hydofoil
Moosehunter
I have seen these on line suppose to help zodiac get on plane faster. There are a few different styles one goes on the motor another style i have seen goes on the back of the zodiac. Kind of like to flat tails. I was wondering if they are needed/worth having? I plan to haul pretty heavy loads (moose quaters) :D as well as just cruising. <br /><br />Thanks.
Moosehunter
Re: Stabalizers/hydofoil
P.s I have a 12.6 Zodiac futura fastroller if it makes a difference.<br /><br />Thanks again.
mrhelper
Did you ever learn anything about this type of equipment? Sounds like we have the exact same boat. I've found that no matter how I trim my motor (a 15hp Honda 4 stroke), the bow of my boat rises to an alarming angle while throttling up if I am solo. If I load someone in the bow, it hops up onto plane effortlessly. But when I'm by myself, I'll need to have something relatively heavy loaded in the bow.
Which has me wondering about this equipment now... Could be a lot handier than a sandbag or cooler!
ZodFutMk2
I have the fin that attaches to the motor. Doelfin...I think. It's been on and off the boat for about six years. Every once in a while I take it off and make sure that it hasn't drooped with age. Since it's black plastic, the summer sun can heat it up pretty good, when the boat isn't in the water.
Some folks have said that the motor mounted type is hard on the cavitation plate. I haven't noticed that issue, I made sure that I drilled the proper size holes on installation and then gave the newly exposed metal a thin coating of epoxy to prevent corrosion.
The fin does improve time to plane and has a positive effect on handling.
Even with the fin, proper trim is important. My trim changes based on load, whether I'm pulling a tube or the size of the waves.
Mine too had the shoot for the sky bow rise, the fin has improved that unsettling motion.
I also moved the massive marine deep cycle battery forward and centered below the second seat.
Hope this helps!
