Stability Issues
jt5120
I recently bought a 1979 18 ft sea star tri-hull. The boat came with a 200 hp Evinrude 2 stroke outboard on it (1980 I believe). I know that this is far too much engine for this boat and I plan on changing it out soon. but for now I'm having issues with stability. When ever I get up to about quarter throttle the boat starts hopping, even when in dead flat water. The engine has stabilizer fins on it and they are kicking quite a bit of water up in the back. If anyone has any suggestions on how to prevent the hopping from happening I would appreciate it. I'm nervous she might flip over if I push it too far. Not sure if this is just a problem with the tri-hull design or something else. Also on a side note the boat came with jack plates that I have not installed yet to raise the engine up a bit, not sure if this will help or not.
Andy in NY
Re: Stability Issues
is it a side to side or up and down hopping? sounds like chine walking...
http://www.youtube.com/watch?v=MJ63zJCtYUs
the fins may be pulling you too high out of the water...
jt5120
It was an up and down hopping and you were right I pulled the fins off, and its gone. Thanks for the advice.
Andy in NY
that is porpoising, and it too is caused by the boat being too far out of the water, then cant support itself so it drops back down... lather, rinse, repeat.
