Stabilizer on Yam 200 o/b
ihzunder
Hi,<br />I need to adjust my stabilizer fin to reduce a significant right hand pull.<br />When I lift the engine, it is certainly not obvious to me how I'm going to move the fin.<br />Can someone please tell me how to do this?<br />Any recommendations as to approx. how far it should be adjusted based on the amount of pull?<br />thanks,<br />Ian
rodbolt
Re: Stabilizer on Yam 200 o/b
remove the rubber plug on the midsection above the tab. use a 12mm socket on an extension. move the tab in the direction of pull. retighten the tab and reinstall the rubber plug.
