robert graham
- Joined
- Apr 16, 2009
- 6,908
Re: Stabilizing gas???
Stabilizers in the gas are like many other Preventive Maintenance items, maybe hard to prove that they Did or Did Not work. Lots of folks replace their spark plugs yearly, "wheather they need it or not", but it makes for good reasoning to try and prevent as many possible problems or equipment failures as possible. I use the stabilizers And drain each carb several times a year, especially at lay-up time....motor is a 1999, and no problems at all, so far!....But if you read the threads about water, varnish, plugged carbs, injectors, filters, etc., the associated costs and headaches of fuel system repairs, Why not do something to try and avoid these. It's been said on here that about 80% of motor problems are Fuel Related, so that's where to spend your time and money to prevent? Good Luck!
