Jfreakman84
Thread starter- Joined
- Aug 2, 2022
- 21
Hello all,
Finally got my boat to start when I wanted it to... https://forums.iboats.com/threads/mercruiser-4-3-not-starting-when-hot.759153/
Rebuilt the carb and still had the issue, finally wrapped the fuel pump and line in heat reflective tape. That seemed to do the trick.
However, now that I rebuilt the carb, I get a full stall whenever I jam the throttle forward. If I ease the throttle it runs like a top. I've confirmed the idle is set correctly both in the driveway and in the water. New spark plugs and it still does it. It seems like when I jam the throttle its pushing too much fuel and causing the engine to flood.
Is there something I can do to fix this or do just need to deal with easing the throttle?
