1976 Johnson 75 HP Stinger - starts OK and sounds OK - but when I put it into gear it stalls out. It will stall about 9 of 10 times and when I do get it to stay going, it only goes really slow (almost no wake). i ran it for a while thinking it might "clear" but no luck.
I have cleaned carbs, replaced coils, plugs, fuel lines, new gas with Sta-Bil, etc. Did compression check and results are as follows: Top = 120; Middle = 100; Bottom = 110
Need some troubleshooting tips. Is compression results the cause for the stalling?
