Stalling Force 120 when popped into gear
pnwboat
Re: Stalling Force 120 when popped into gear
You've got the general idea. You can also refer to Frank A.'s guide on "Synchronizing Carbs and timing on a 75 - 150 Chrysler or early Force" Steps 6 - 10 explains in detail how to adjust the carbs to minimize the stalling.
http://forums.iboats.com/showthread.php?t=431021
brianvolt7
Thanks pnwboat, nice to hear from you. Thanks for the link!
brianvolt7
Dead in the water, I broke the timing link rod connector. Know where I can get one?
pnwboat
You mean this little doohickey?
brianvolt7
Yah, I superglued mine back together and am going to set try to set the timing in the morning. I found one on ebay 69 dollars though. I just need the side that goes to the ring under the mags.
jerryjerry05
boats.net has the setup.under 10$ 85 H.P. (1988) Force Outboard 853X8B POWERHEAD Diagram and Parts#32 and 26
F499035
F499036
brianvolt7
Many choices on boats.net for these two part numbers. Do you know which one in particular I would need?
brianvolt7
Thanks for all the help. It's done and running perfect. My last question is, instead of adjusting the tower shaft, why wouldn?t I have just adjusted the linkage between the tower shaft and the throttle plate? This appears to accomplish the exact same results without adjusting the timing, or does it?
pnwboat
Adjusting the tower shaft will slightly alter the timing at idle. Adjusting the linkage between the tower shaft and throttle cam usually does not alter timing because the tower shaft itself does not move. Just the throttle cam moves.
dfrich
you can order it online at iboats.com
