Hello all! Hopefully someone can help me out on this. I just rebuilt the carbs with a OEM kit. My engine is 93 115hp....... VJ115TLETS. Took the boat out this past weekend and it wouldn't stay running. It would run, then die out (in the water) on the muffs it was fine. I finally got the motor running long enough to get it out on open water and once i opened it up it was fine at WOT and any other speed except idle speed. I read about adjusting the low-idle mixture screw, but i don't think my carbs have a low-idle mixture screw or im just over looking them. Any suggestions on what can can causing this. BTW i rechecked to see if the float & needle was stuck and there fine.
