standard horizon 160c gps
oddysea1
Had battery charger on,gps on, turned over engine and must of shorted out gps.On and Off switch doesnt work, gps stays on with just a lit blank screen.Question :any inline fuses or fuse inside unit that can be replaced?Also is there a reset button if so where?Any help appreciated!! Problem solved!! Took unit out of electrical bracket and put back in several times, the screen indicated a restart mode, I did this just to experiment and it worked.
