starcraft 176 sportfisherman leak questions.
vanner78
Hello,
My brother has a 2004 or 2005 starcraft 176 sportfisherman with console, and for some reason it leaks water onto the floor in the back corner of the boat, even when the entire bilge is mostly dry. What could leak water onto the floor without the entire boat being full of water????
Huron Angler
Re: starcraft 176 sportfisherman leak questions.
There should be a plug you can put in the livewell drain to keep water out if it's leaking.
If that doesn't work I'd just put a plug in the intake thru-hull fitting, that will keep the whole program dry.
Hope it's that simple for ya:)
