Re: Starcraft american 16
Hi Brian,<br /> Yes, I ground the transom area smooth with an angle grinder and belt sander. <br /> On my 15-foot hulls, I was able to pull the entire stringer out on either side, leaving the fiberglass "tunnel" in place up under the kickboard flooring. They were loose in there once I removed the rotted aft portions of the stringers. I used the smaller pieces of the original stringers as patterns when making the new ones so that they'd fit into the old glass tunnels. I goobered them up good with thickened epoxy before sliding them back in, then screwed them in from the top through the existing floor. <br /> I left the original floor starting at that original plywood seam, just before the kickboard with everything aft of that being new. Both of my small hulls had been stored bow up a bit, so the forward keel and flooring weren't bad at all. <br /> I've been kind flying without a net as far as books are concerned. I've worked in a few marinas and boat repair shops over the years, as well as helped friends build some racing hulls, so I've picked up lots of info that way. Plus, I found lots of good info here on iBoats, too. There's no real rocket science to it, and as I'm sure you've figured out by now, your Starcraft's original construction methods weren't all that great, anyway, so more than likely you're going to build it better than it ever was originally. On mine, all wood is encapsulated in epoxy, the transom is full thickness top to bottom, side to side (original was not), and not a single steel screw to be found anywhere in my reconstruction. Not a knock against Starcraft, but they certainly didn't figure their hulls would still be in use 30 years down the channel.<br />- Scott
