crackedglass
Thread starter- Joined
- Jan 4, 2009
- 207
I was given a 1973 Capri 17 today, it's been sitting in a barn unused since 1975, the interior is trash, mostly just badly rotted from age, the carpet is green astro turf, and the floor has the rear panel removed from where I was told they intended to install an in floor cooler. The lower hull has no visible foam, the stringers all look great, the transom holds my 325lb self with no flex, and the wood deck is dry and intact. Through the cut hole I can see that the floor don't sit on the stringers in this boat, it's at least 4" or so above them. I take it that was to level the floor over the trihull form.
There are sheet metal tabs between the floor panels, and light wood strips run between the seems supported with a few more strips atop the stringers.
Anyhow, the question is, first, I'd want to put the floor back to stock, no hole, no cooler, what's the best way to patch or cover a cut hole in the floor about 2'x3' which is directly between two panels of the original floor?
Next, it's got a siezed Mercury 50 on it, most likely the original motor, but its just sat too long. It looks like new but is locked up tight. I pulled the plugs and shot in some penetrating oil but I doubt that will help.
The manual says it's rated for a 135hp, but the Coast Guard plate says only 110hp?
I have a 1995 Mercury 115 ELPTO that would fit, its that or an Evinrude 50 from the mid 70's. I'd like to see this boat set up with two pedestal seats and a painted floor for fishing, no other interior at all. It's pretty light, I can lift the bow or stern off the trailer myself, so it's not all wet and water logged like so many others I've seen.
Has anyone had a Capri apart or have any adivice on the floor or motor?
