Starcraft Fishmaster 190 REDO
SPLMAXSAM
Mercury 140 is giving me some grief. No spark on 2 and 3 after replacing a bunch of rotting wire. Got 2 to fire after replacing switchbox. going to work on it this weekend 087.jpg
SPLMAXSAM
No Title
On my current boat i had a problem storing drinks food and fish. So hopefully new boats cooler seats will fix that problem
GA_Boater
Is the High Water Alarm only an alarm or is does the light turn on when the auto bilge pump kicks in?
SPLMAXSAM
Alarm sounds on float switch
Light turns on when bilge is running
SPLMAXSAM
No Title
I have wired my boat using anderson high current dissconnects. This allows me quick access to a battery or moving a batery in the boat. I use 2 batteries for trolling. I use 1 battery for starting and electronics. If my starting battery gets weak. I can jump it or replace it using another battery
SPLMAXSAM
No Title
My trolling motor is 24 volt. I have to series 2 batteries to make proper voltage. The anderson dissconnects make it easy to donthat
SPLMAXSAM
No Title
Took some time off from the boat (dang work) and a little fizzon
Watermann
Dang you and those monster eyes! Our bite here in WA won't be on until pre-spawn in Feb & Mar.
SPLMAXSAM
No Title
The outboard needed a few parts. Some where routine tune up. Others were replaced for dry rotted wires
SPLMAXSAM
No Title
Sometime it takes a second pair of eyes to see the obvious promblem. Kimba the boat mechanic took one look and saw my spark issue. Bad coil ( slight buldge or crack) and a weak ground
We then put outboard into 55 gallon drum and added some fuel
Motor started up. Ran smooth, but all 3 carbs PUKED gas.
SPLMAXSAM
No Title
Turned out during the rebuild of the carbs. Part 4 and 5 were reversed and part 4 was inverted. This caused the needle to never seat properly.
Then diaster struck -1 needle fell out. We heard 1 ping and then silence. After searching for 1 hour our in transom, boat, outboard and the sewer directly below the motor, i have to order another needle
Watermann
Oh man that's a bummer, one of the things that ticks me off is dropping something and the hunt that ensues.
Good progress, I hope that doesn't keep you from getting her in the water before freeze up.
SPLMAXSAM
No Title
We will try the launch next monday or tuesday if the wind and waves are good
I am not too afraid of ice thing. Been there trying to get and carch some fish
SPLMAXSAM
I think the outboard is up and running. While I was working, my buddy reconfigured the carbs.
Next on the list -10hp licker
SPLMAXSAM
No Title
Had a couple of buddies come over and help knock off a few items on the check list, along with a few adult beverages. One job i hate is trying to put decals on a straight line. My good buddy helped me. He read the instructions and drank 1 adult beverage. He measured wonce! Drank 1 adult beverage . He applied. Drank 2 adult beverage. He went to the port side. He applied I will let him finish before I point out some minute concerns I have.
