Starcraft ID plate
v8mgbal
Hello all. is there anyway I can find the serial # that was on the ID plate that blew off on the way home after I bought my boat. you can see in the picture where it was on the rotted transom which I can't figure out how it rotted with the drain holes LOL. can I use the registration # some how to get the # or is it stamped somewhere else on the boat thanks.
irish24
Re: Starcraft ID plate
I found a second plate on my Starcraft. My model has a pad rail that pads the interior length of the boat. It was under the pad rail on the driver side of the boat. It was dumb luck to locate but found during restoration. Also your registration/title should have it too. Good luck.
v8mgbal
Thanks Irish that's what I was hopeing to hear so with luck I will find it on the boat. If I do have to do it by the reg. # who would I contact to get it thanks again.
irish24
Try a search for your Hull ID on google.
