Starcraft Jupiter 1960 16 ft
mrgintz
Re: Starcraft Jupiter 1960 16 ft
Took the ob out yesterday...the resto on starting line!
mouse's nest
this original floor (52 years) is in good condition. Perfect for template!
mrgintz
old tires w/ moon hub. any suggestion how to re-chrome the hub? rust is pretty deep.
new tires from farm & fleet. they were on sale $67 for each 5.30/12 tire & rim.
mrgintz
found few gallons of water sitting under the styrofoam flotation.
other side of floor...
I think power washer would be sufficient.
GA_Boater
Progress, progress, progress Mr. G. I don't think the baby moons will fit on the new wheels. Re-chroming $$$ might knock your socks off, too. The floor seems to be in good shape, the bottom any way. The inside of the hull looks fairly clean. When you pressure wash get the rib drains (I forgot the proper name) right down the center cleaned out. All years of dirt, mouse doo-doo, etc, like to block them and water can't get back to the bilge. Keep it up and you'll be splashing soon.
jbcurt00
That may be the cleanest SC hull post demo yet.
Great looking!
jbcurt00
I believe that your looking for: lumber holes:)
InMotion
Great process MR... nice and clean and prolly smells a lot better now the must water and mice nest are out!
rheagler
Nice project Mr G. Now comes the fun part... No wait, all this is fun!
mrgintz
We're both having trouble with that one. LOL But you jogged my memory. Limber holes. Thanks JB.
My jup has only one stringer..however no limber in the center. It has three knee braces. I have hell time getting rid of all dirt between knee braces. Will try shop vac. any better technique?
MG
mrgintz
Transom bracken taken off...
mrgintz
Took me the time to remove the splashwell drain holes out. Placed car jack for transom removal.
Sprayed 10-40 between wood and aluminum.
Easier than I thought.
Cheers,
MG
mrgintz
Wood transom appears in good shape after 52 yrs. Great for template.
mrgintz
Slide off the trailer...
Then flipped by myself...
mrgintz
millions of pits....
Almost everything about this boat works and look good except for the bottom of hull....
JB weld? May have to spread out JB on entire bottom....is there better way to do this?
GA_Boater
Mr. G. - Any corrosion inside the hull? Any leaks? I don't know about JB on the outside.
mrgintz
GA,
I water-filled the boat....no leak at all. This week I will use Mar Hyde aircraft coating remover...then I will go from filling the pits.
MG
