Andy in NY
- Joined
- Oct 25, 2007
- 2,109
Re: Starcraft project: "STOLEN" PAINTED!!! PIC UPDATE 7-12-09
well, the main reason I was going to install it was to hide all the freakin holes. the origional motor had 9 holes to bolt the motor... 4 for the motor bracket and 5 for for the power trim brackets. they are a bit big to just fill, and i really cant afford to pay someone to weld in plugs...
what would you do about the holes??
so should i skip the pt for the side panels as well and go with ex grade ply coated with resin instead???
I skipped the piece on the outer transom. Didn't appear to serve much purpose and it looks nicer without it. I'm on my 2nd season without it to no ill effect. I'm also pretty sure you don't want to use PT on there. If you do reinstall it (I really wouldn't) definitely 5200 the edge and around all the holes.
I'd use staples AND adhesive for the vinyl.
