brobrad
Thread starter- Joined
- Jun 19, 2009
- 246
Re: Starcraft SuperSport Restoration (18 footer)
I took the Merc out for the first time. It ran like a scalded dog. I CAN NOT BELIEVE i left the GPS at home, but i did. the 21 pitch prop jumps out of the hole great and runs on the top end well. Without a tach i don't know if i was maxed out. i was a little conservative with the throttle. I would guess we hit the 45mph mark. I've got to adjust the throttle cable a bit as idle is too low. It idles rough running only on two anyway, but needs a bump up.
The one thing that did scare me was turning the boat with the motor trimmed down. my son was sitting on the starboard side with his arm propped on the side. My other son fell off the tube and i made a hard turn and it banked so deep it put his arm under water and it appeared that i could have turned it over. I was still trying to play with how it functioned. I trimmed it up a pretty good bit and the next time it gave me some "slide" in the rear and felt much better than the banking. I never did get my wife to run so i could check out the position of the motor in the water at WOT. Tach should be here this week. Next time i'm taking GPS and camera.
