started grinding today! have a few questions!
Lwarden
I used all proper gear and I must admit, it's not as bad as I had read about. Maybe because I used the proper gear?.anyways when you guys are grinding the layup/ tabbing material where the old stringers were do you grind to the original hull material? Im grinding till I can see the woven, is this proper technique? around where the motor mounts were that layup is superthick should I grind that to original woven also? and also,on my tansom I have a layer of what looks to me like CSM? do I need to grind that back to original or can I leave it and just rough it up/smooth it out?
mwe-maxxowner
Re: started grinding today! have a few questions!
I just ground till nice clean looking glass with no bubbles. From my researching nice clean pink glass is all that's required, not necessarily to a certain layer. I also felt like you say about the grinding, it really wasn't so bad. I think it's just all in how you look at it :).
I ten to one prefer grinding to glassing.
try a paint scrapper on the woven if you can not get under it then clean it with the grinder. on mine the roven was applied alittle dry so i could scrap up a edge and just pull the whole sheet off. you just need something thats clean and well stuck for the new stuff to bond.
Woodonglass
Honorary Supreme Mariner
The important thing to remember when grinding is
Lwarden
I think the woven is the hull material!
mwe-maxxowner
"To liberally wash the area with acetone"
Somehow woods post was spread across three different threads.
Lwarden
Most of it is coming up ok! I just dont want to grind any deeper then I need to. The bilge area where the motor mounts used to be is really thick and I need to get all that out of there. Should be ready to build the transom this weekend maybe get it glued in.
Lwarden
Thats prior to reglassing right?
mwe-maxxowner
Yes directly before glassing sweep your area, shop vac it, and wash down *well* with acetone.
Bomber Goober
I think this may of been done on purpose. If so :laugh: , I see where he is coming from.
Lwarden
Yea I get it!
