BonairII
Thread starter- Joined
- Jun 7, 2011
- 2,727
After doing a ton of reading on the many different decarb procedures...I decided that I wasn't going to wait any longer. (Talked to PO and he had never done a decarb on it)
Warmed up the motor this morning then pulled the plugs and heavily sprayed each cylinder(at TDC) and let the motor sit all day.
Just started it up about 30 minutes ago and let the motor start sucking up the gallon of Seafoam/Premix. Lots of smoke, so it's def doing some carbon removal.
The video is about 5-10 minutes into the first round of the decarb.
http://www.youtube.com/watch?v=vzqgktoIOl4
No wind, so most of the smoke is going upwards instead of engulfing the neighbors
Update: Just ran her another 10 minutes and the smoke is still coming out thick with no signs of letting up. Def must be a lot of garbage in there. I've only got about a 1/4 gallon of the "mix" left.
Probably going to have to mix up another gallon and continue running it tomorrow, if the smoke doesn't stop.
Second Update: Ran her for the third time and the smoke just keeps coming and coming. I went thru the gallon of "mix", so I'm done for the night. Going to mix up another gallon and do it again tomorrow.
