Starter/ Battery ?????????
boneheads
First I had a short you all helped me fix,then my starter turned slow,so on your advice I changed it. Started fine for about eights times then we stop, I try to start again and all i here is a click then I notice smoke coming from where my batteries are and my Neg post is melted.NOW WHAT IS MY PROBLEM??????? I Just Laugh:D
puddle jumper
Re: Starter/ Battery ?????????
Poor connection caused a amperage drop on the negative post which caused
heat which caused the post to melt.
Just my two cents.
eurolarva
Or your new starter has a short in it. It would be a drop in resistance and a jump in amps that would have caused the smoke. Does your starter still work?
boneheads
NO, My starter no longer works. Also what all doses it take to rebuild a starter???
boneheads
One more Question. When I replaced the starter it has a bracket on the bottom that bolts to the motor, it is misssing could that be my problem????
boneheads
NO, My starter no longer works. Also what all doses it take to rebuild a starter??? One more Question. When I replaced the starter it has a bracket on the bottom that bolts to the motor, it is misssing could that be my problem????
