Re: Starter bolt snapped! 91 5.0 mercruiser
I have removed bolts from engines before by grinding a drill to cut in reverse. It kind of goes against the flutes on the drill, but it works. If you are able to, grind/sharpen the drill to cut in reverse, and get a hold of a drill machine that you can put in reverse. The counter clockwise direction will be trying to turn the bolt in the correct direction for removal, and the heat generated during the initial cutting stage can help free the bolt, and hopefully the drill digs in, and winds the bolt out.
