johnsland8
- Joined
- Jul 12, 2008
- 56
I have a Mercruiser 165. I just completed a motor swap and now am having problems with wiring/electrical.
I have traced all engine wires and everything appears to be "ok" but I must be missing something.
My starter has 3 terminals. Main battery terminal, "S" terminal to start, and "R" terminal for power to coil.
When I turn the key on, I get power to the dash and everything but I get no power at the "R" terminal on the starter to energize the coil. If I turn the key to start the starter will crank the engine (of course it won't start because the coil is not powered.). I can jump a wire from power to the coil and it will start and run fine.
Before my motor swap, it was starting normally but would not shut off when I turned off the key. Is this 'R' terminal a relay that could be bad? what am I missing?
Thanks!
Thanks!
