I have mercruiser 3.0. I had a broken starter bolt which I extracted and replaced with mercruiser original starter bolt. Since then my starter is not working while installed on the engine.
It works fine when bench tested and as long as I install one of the 2 bolts. I have to leave the bolt loose for it to engage the flywheel. As soon as I insert the second bolt or try to tighten the first one, I hear a whining (spinning) sound without engaging the fly wheel. I have tested the solenoid, the connections, voltage drop test, ground and + all check out.
Has anybody had similar issues? Any pointers will be appreciated.
