FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Does anyone replace/rebuild their starter motor as a maintenance item? Or do you just wait for it to fail? My 90 hp johnson outboard is 16 y.o. now, assuming the starter is original and works fine...Just wondering what you guys have done.
Unless you encounter a crank but no start situation and just keep cranking 'til the smoke leaks out of the starter, it usually gives you fair warning that it needs work. If you don't attend to it then, there's a good chance you'll wind up dead in the water.
Mike
mine is also 16 yrs old (2001), I disassembled it 2 months ago due to starting issues, all was good, checked, cleaned and reassembled, ended up being battery and wiring issues. otherwise wouldn't of bothered it.
The starter on a 90HP Force got so it was cranking slow. After checking all connections and batt load test I pulled the starter, disassembled and cleaned it. Put some grease in the shaft bushings and it cured the problem for 9 yrs until I sold it.
Mike
Even if it is working fine, at that age it would be perfectly reasonable to have the brushes replaced as a minimum. Most starter/generator shops can also replace the end plate bushings and dress up the commutator thus giving you an essentially new generator for a very reasonable outlay.
Easy to do yourself.----I install brushes all the time at $4.50 a set.--Bit of lube on shaft and re-assemble.--Nothing to it if you make a simple tool to hold brushes in place.
