EdwardNigma
- Joined
- Dec 26, 2005
- 30
I'm looking at buying a boat with a 1978 175 hp Johnson outboard. The owner has let me have it for the winter to look it over prior to completing the sale this spring, pending me being satisfied that the motor isn't junk. I posted about this a few weeks ago and got some good advice on what to look for if I could get it running in a tank.<br /><br /> I decided to try some of that advice yesterday and ran into some a snag, possibly a big one. In one way or another the starter is failing to do it's job. I started out by trying to use the battery that came with the boat. This battery looks like she's been around for awhile, but this fancy smart battery charger I have thinks the battery is in decent shape. When I turned the key the starter spins up and the bendix pops about half way up the shaft and just spins there. It's still well short of engaging the flywheel<br /><br /> I tried greasing the shaft that the bendix runs on in case it was sticky from age. No change. Next I suspected the battery so I pulled out my charger which has a 100 amp engine boost and tried that. No change. Upping the ante again, I pulled a relatively new battery out of a car and connected it to the original battery with jumper cables. Same thing, bendix moves up maybe an inch and just spins.<br /><br /> Next I tried turning the bendix up by hand and engaging the flywheel, then turned the key. This at least got the flywheel turning, but too slowly to start. You could see it struggle and slow on the compression stroke and then speed up a little on the downstrokes. Again, nowhere near fast enough to start it.<br /><br /> Finally I tried disconnecting the old battery and connecting the known good battery directly to the motor. This got the bendix to come up and engage on it's own, but the motor turned even more slowly than before. It barely managed to get past the compression stroke.<br /><br /> So this leaves me wondering what to try next? Is this a bad starter? A bad solenoid? Should the battery cables be replaced? Is there some way to test the starter motor? Any help would be greatly appreciated.
