bkhealey
Thread starter- Joined
- Aug 20, 2012
- 45
Hi, I think my starter is toasted but wanted to make sure. The battery has a 90% charge and connections are clean. But when I try and start the motor it acts like it isn't getting anything. The starter just turns once and that's it. Then stays engaged to the flywheel. I looked at the connections on the starter and they are tight and clean. Would anyone else have an idea?
Thanks
Brian
Update: I took my volt meter and touched the positive input on the solenoid and that was good. But the output end would show good then drop to 0. Then the starter turned once and stopped as the volts dropped to 0.
Thanks
Brian
