I think starter is bad, clicks but won't crank. Battery 12.5 volts, all cables cleaned, tried new ignition switch. Can I use the insides of a Chevy automotive starter and install in my sealed marine case? Price is $400 for a marine starter.
First, troubleshoot what the issue is. most likely bad connection and or a bad slave solenoid.
most likely its just a bad connection.
NO, you cant use the insides of an automotive starter. I paid less than $200 for a polished stainless performance starter
I dont think I paid more than $60 for a standard marine starter (hint, dont buy it from volvo)
there are 4 GM marine starters. direct drive or PMGR, and straight across (for 153 tooth flywheel) vs staggered (for 168 tooth
How's the quality on these? Price is great at 79 delivered.
They seem to be fine, my self I buy API 10105 which is around $150How's the quality on these? Price is great at 79 delivered.
I finally took it apart. Looks like it was submerged at one time. Amazing that it still worked. Commutator has chunks missing.I think starter is bad, clicks but won't crank. Battery 12.5 volts, all cables cleaned, tried new ignition switch. Can I use the insides of a Chevy automotive starter and install in my sealed marine case? Price is $400 for a marine starter.
Ayuh,..... You got the last lap outa that one,......I finally took it apart. Looks like it was submerged at one time. Amazing that it still worked. Commutator has chunks missing.
