Forceluver
- Joined
- Aug 25, 2003
- 36
HERE IS THE PROBLEM!! I WAS TESTING A FRIENDS BATTERY TO SEE IF IT HAD JUICE, SEEMS LIKE IT DID NOT, SO I SWITCHED BACK TO MY GOOD BATTERY, AT THAT POINT EVERYTHING WAS STILL DEAD. I FOUND THAT I HAD TO RESET THE BREAKER, SO I'M CONVINCED I MUST HAVE PUT THE WIRES ON THE WRONG TERMINALS, THAT OR THE OTHER BATTERY WAS THAT SHOT. EITHER WAY WHEN I TRY TO START IT NOW THE SOLENOID EITHER CLICKS OR DOES NOTHING, IF I TURN THE KEY SEVERAL TIMES FAST BACK IN FORTH IT WILL START, AT LEAST IT DID NOW IT DOES NOTHING. WHEN I HOOK UP 12 VOLTS DIRECTLY TO THE STARTER I GET A REACTION FROM THE STARTER EVERY TIME.
