How do you get to the starter on a 1998 monteray explorer to replace it? Thanks
J jlarry111 Recruit Joined Apr 6, 2010 Messages 1 Jul 16, 2010 #1 How do you get to the starter on a 1998 monteray explorer to replace it? Thanks
zbnutcase Commander Joined Sep 19, 2009 Messages 2,055 Jul 16, 2010 #2 Re: starter replacement on 1998 monteray explorer Hard to say without looking, but not uncommon at all to have to remove an exhaust manifold or even remove the whole engine, starters can be a real P.I.T.A.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,464 Jul 16, 2010 #3 Re: starter replacement on 1998 monteray explorer Ayuh,... Either remove enough of the boat to reach it, or pull the motor...
C Creck Recruit Joined Jul 16, 2010 Messages 4 Jul 16, 2010 #4 Re: starter replacement on 1998 monteray explorer I have a 97 and just changed out the starter. It's a little tight, but with a little work you can get to it without taking the exhaust off. Good Luck
C Creck Recruit Joined Jul 16, 2010 Messages 4 Jul 16, 2010 #5 Re: starter replacement on 1998 monteray explorer You may want to consider shims. I had to use .0400 shims to get it to stop binding. Good luck and happy knuckles.
N nitrosteve Petty Officer 2nd Class Joined Jul 19, 2009 Messages 155 Jul 16, 2010 #6 Re: starter replacement on 1998 monteray explorer Bond-o said: Ayuh,... Either remove enough of the boat to reach it, or pull the motor... Click to expand... Well said....
