I'll try and explain my problem. I just finished rewiring the engine and harness. Now I can jump the starter with jumper cables. But when the remote harness is hooked up and I turn the key I get nothing. When I test the switch leads to a ground on the motor I get 12 volts on all but one (this wire goes to one of the middle screws on the solenoid). Now on the solenoid I got 12v from the big red wire to a ground, but the two little screws in the middle I get nothing. The manual just say test for 12 volts??? Is my solenoid bad or I guess I should ask, how do I test it. I cannot jump the solenoid but I can jump the starter.. <br /><br />If needed its a 1968 65hp Evinrude model # 65853<br /><br />Thanks
